RJsfishin's avatar
RJsfishin
Fridge won't stay burning in hot sun
Fridge works perfectly until the hot sun get on the outside grill, usually starts going out (F code) about 2 pm. It will lite back up no problem, but will burn only 10-15 minutes. At about 6 pm, it work like a new one again.
I'm sure it must be electrical shutting off the gas valve,.....pointing to a control board over heating ???
Think a small fan moving some air in the outside compartment mite help ?.
It really isn't a problem as long as I remember to relite it, but if it mite be a simple fix, such as a small fan, I'd try it.
  • I'm near positive its not a propane problem, but I'll check the stove. If that is still burning right on flameout, I'm thinking I should watch the voltage on the gas valve when it flames out.
    Thanks Doug
    dougrainer wrote:
    The heat build up from the sun is minor compared to the heat generated by the LP burner. I have NEVER had or heard of a heat issue causing a Control board malfunction on a refer. When this happens again, fire up the refer on LP and immediately lite the stove top burners(all 3 or 4). See if the stove top burners either do not all light or the flame is very low. I would suspect heat causing the LP regulator to malfunction. You DO have clear unobstructed ventilation all the way up the refer roof top vent? Doug
  • The heat build up from the sun is minor compared to the heat generated by the LP burner. I have NEVER had or heard of a heat issue causing a Control board malfunction on a refer. When this happens again, fire up the refer on LP and immediately lite the stove top burners(all 3 or 4). See if the stove top burners either do not all light or the flame is very low. I would suspect heat causing the LP regulator to malfunction. You DO have clear unobstructed ventilation all the way up the refer roof top vent? Doug
  • It's extremely difficult to troubleshoot your problem over the internet when we don't know what year, make, model of trailer with or without slides, etc.
