fitznj
Sep 16, 2015Explorer
"100# water pressure..........GOOD REGULATOR !!! "
My thoughts exactly........ a high water pressure reading does not make it "good".. With those numbers. I would disconnect the water each time I leave. This kind of pressure will blow apart the water fittings - I would not trust the regulator (in this instance), I've had one which partially failed and took out a water fitting.
Gerry
Gerry
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
