myredracer
Sep 16, 2015Explorer II
fitznj wrote:
"100# water pressure..........GOOD REGULATOR !!! "
My thoughts exactly........ a high water pressure reading does not make it "good".. With those numbers. I would disconnect the water each time I leave. This kind of pressure will blow apart the water fittings - I would not trust the regulator (in this instance), I've had one which partially failed and took out a water fitting.
Gerry
High water pressure isn't a problem for us and we can handle up to 200 psi (limited by the hose). I installed a Watts regulator inside and modified all the plastic pipe and fittings to brass upstream of the reg. Also have a high pressure Valterra hose. I installed a tell-tale gauge in the incoming side and somewhere this season the pressure got up to 120 psi. I've heard of some places getting up to or near 200 psi.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
