Bob_Landry
May 03, 2014Explorer
trop-a-cal wrote:
The outside unit may have a stuck cooler fan shaft. That can be overcome by pushing the fan blades that will rotate the shaft so it frees up. Do that before turning on unit. I use a wooden dowel about the size of your little finger in diameter and about three feet long, as it fits through the slotted openings in the sides so you don't have to take shroud off. The compressor won't start until fan outside is rotating, as it cools condenser on one end and blows air over the cooling coil and into the RV on the other end. The shaft gets rusted in place due to age and lack of use.
There is no start components or control between the compressor and the fan. Each is controlled and runs independently of each other. Also, the condenser fan draws outside air into the shroud and across the condenser coil and then exhausts the hot air out the rear of the enclosure. No outside air is ever directed into the trailer. The air inside is constantly being recirculated through the evaporator coil.
I'm amazed that some of this stuff gets posted, but then it is the Internet.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
