ceasare's avatar
ceasare
Front tires on the truck
Came back from our 10,000 mile trip cross country again. Went to rotate the tires and get an alignment, and the front tires had sone scupping. They only have 30000 miles on LT tires. Could it be from towing the 5 wheel?
  • Cummins12V98 wrote:
    What air pressure are you running in the fronts? What tire size and load range?
    I'm not the op.
  • 2oldman wrote:
    2019 Chevy 2500HD gas 2017 jayco Eagle HT 28.5
    Do you know your loaded and un loaded axle weights?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    More likely an alignment issue. But follow the link someone posted from Google.
    I typically get 60,000 miles before new tires (thread still good I'm just anal about tires)
    Tow a 14K 5th wheel.....7 yrs was FT
    NO front tires wearing out in short mileage has nothing to do with towing 5vr
    What truck do you have....year/brand/model etc?
    What tire pressures are you running...front & rear----towing/non-towing??
    Suspension, ball joints, shocks, weight on front tires/air pressures etc
  • Mine do that too, so I always rotate them every 5,000 miles. I always thought it was from my off road driving in FWD.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
