mlts22's avatar
mlts22
Explorer II
Jan 23, 2014
Fuel cutoff solenoid for Onan gensets?
For storage, I've wondered how useful it would be to have either a fuel petcock valve on the line, or if one wanted to get fancier, a solenoid activated fuel valve (so it could be turned on/off from inside.) This way, the generator can be shut off via this method, which would run the fuel line dry, as well as the carb bowl.
Would this be worth doing as another way to protect against fuel varnish? I know this helps with portable generators since if they get run dry, there is no fuel to go bad inside the tiny jet areas.
  • There's two trains of thought on this:
    1) Run dry
    2) Treat and store full
    Problem is, there's always a drop or two remaining in the critical jets even when shutting down the fuel input. In my opinion, it's better to treat the fuel with stabilizer and run the equipment sufficiently to pull in stabilized fuel, then store full or run dry, but at least the fuel has been stabilized.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
