Neptune03dog
Feb 06, 2014Explorer
Thanks Fishinghat, I will find or make new ground. My fuel tank is full but generator will not run. I cranked it up to let it run for an hour or two as I do every two weeks when not using and it ran about 5 minutes and then quit. The starter works but it will not crank. I replaced the fuel filter but still does not work. Had fuel hose replaced about 200hrs ago as it had cracks and was sucking air. Ran fine until now. Not sure I want to tackle dropping tank and replacing sensors or tubes. Once again thanks for your response
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
