waynefi's avatar
waynefi
Funny water pump leak
I’m getting a strange water leak in my TT. It will occasionally dump a half cup of water onto the floor below the water pump.
I look once, it is dry. I look again an hour later, it is wet. The it won’t happen again for days. I can’t find any pattern to it.
Of course, when it was i at the dealer’s, this never happened.
Has anyone seen anything similar?
The pump is s Flow Max in an rPod 195.
  • ^Just google “rvnet photo posting”. TAkes you to an old thread here with a link.
    From there it’s pretty easy. A little clumsy and not convenient but not difficult.
    Your water issue is perplexing though, especially if you can’t catch it in the act or see evidence of where it’s leaking from.
    One thought, maybe get a helper and cycle the pump on off, drain pressure from lines each time. Should be able to do that repeatedly in not a lot of time. And just watch that sucker until she squirts!
  • Answering a couple of questions about my leak:
    This is using the pump. I rarely connect to city water.
    I tried the paper towel trick, but I have never caught it in the act. The towel is either completely dry or soaked. I tried putting a little tray under the pump. It does catch the water, but I can’t tell if is inlet side, outlet or the pump itself.
    This is a brand new trailer. We saw the leak 3 times on a 10 day camping trip. The pump was on the entire time. It may be that the leak only happens when the water heater is on, but still not every time. The heater is nowhere close to the leak.
    I’ve seen the leak twice in the week since the trip. Both times it happened like this: I decided to shower i the trailer to see if that caused the leak. I turned on the hot water, and waited. When I went back out, the spot was already wet. Dried it off, took a shower, and checked it again. No additional water after the shower.
    In order to post a picture, I need to put it somewhere else on the web, and then link to it, right? I’m not sure where to put it.
  • Posting some pictures of your setup might help us give better answers to what might be the issue.
    From what you told us, there is one possibility that might cause the puddle to leak and then not leak. Since I can't see your setup, consider this a generic answer as I have seen this on any connection using a swivel fitting in an RV setting.
    At the piping ends of most RV style water pumps are swivel fittings to allow you to screw the hose or piping onto the pump and not have to spin the pump to get them to go on. Many of those fittings are in the PEX style family of swivel fittings. The fittings look like this, your brand might be different.
    On the end of the fitting is a cone washer, look like this,
    This is the cone washer by itself as a replacement from Flair-It company.
    Those swivel fittings sometimes loosen up and drip. Sometimes the cone washer was jammed sideways when installed and did not seat right and they drip. When the camper get old, like 10 plus years etc. the washer gets a little brittle some times and being compressed long enough start to drip.
    Assuming your pump has a fitting similar to the ones I showed above, first just try and tighten the fitting. Most times that stops the leak. If that does not stop the leak, then change out the cone washer.
    Now showing up on newer water pumps they have swivel fittings with no cone washer, they use a plastic nut and inside the fitting wedge cone to create the seal, they too can leak if they are loose. There is no cone washer to replace, but the loose fitting or a damaged wedge cone can leak. The fitting looks like this from Shurflo https://www.amazon.com/SHURFLO-244-2926-Straight-Wingnut-Adapter/dp/B002IZJ7CW/ref=asc_df_B002IZJ7CW
    I find it helpful to put dry paper towels under a suspect leak area. The monitor it often, and have the pump on to pressurize the system. If you catch the drip in the early phase of the leaking, then you can see where on the paper towel it dripped and help back into where it came from.
    You did not say if you were on city water or only using the pump and fresh tank. Pump leaks can happen from both water supply areas, but city water hookups can have very high water pressure that can aggravate a fitting leak more then the onboard pump can. Have you noticed this problem more on city water or using the onboard pump?
    Hope this helps
    John
  • Or maybe the system has to sit unpressurized for a few days and then leaks the first time it's pressurized.
  • only leaks when pump has presure on the lines, might sit and watch it ,could be gasket at strainer. cracked strainer housing. loose clamp,and on,an on.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
