dougrainer
Jun 17, 2022Nomad
time2roll wrote:
I would check if the high limit switch is shutting off the burner. I believe the switch is normally closed and should have voltage on both sides. Recheck as the burner goes off and then back on. Probably a long shot.
As I stated, it depends on the burner cycle time. A bad limit switch will not cycle faster than 1 minute or so. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
