Dutch_12078
Oct 28, 2017Explorer III
One of the first things I try when the board is suspect is to pull off the wiring edge connector and clean the contacts on the board with a pencil eraser. It only takes a small amount of corrosion to cause the furnace to malfunction. The "quick fix" is to just slide the connector on and off a few times to let it self clean, but the longer term fix is to properly clean the contacts. I also keep a spare universal board from Dinosaur on hand that will work with either our furnaces or water heater.
