old guy wrote:
you will benefit with more power with the 6's then with one or even with using two 12's. the 6's will last longer
A generalized statement that simply isn't true - a pair of G31 12 volt deep cycle batteries wired in parallel offer approximately the same AH capacity as a pair of GC-2 6 volt deep cycle batteries wired in series. For those running heavy loads with an inverter a pair of 12 volts can actually be preferable as they're more likely to suffer less voltage drop under heavy inverter load than will a pair of 6 volts. The devil is in the details. ;)
