Braces's avatar
Braces
FURNACE FAN POWER REQUIREMENT
2014 Montana High Country Thinking of changing to two 6volt batteries. Don't have access to my trailer right now and need to know how much power the fan uses to see if running furnace at night when cannot run the generator would be practical. No genny 8 to 8 in national park. I realize there are a lot of variables so if you know the approx power draw of the fan motor maybe I could have a reasonable idea of the amp/hrs needed to keep reasonably warm.
  • old guy wrote:
    you will benefit with more power with the 6's then with one or even with using two 12's. the 6's will last longer
    A generalized statement that simply isn't true - a pair of G31 12 volt deep cycle batteries wired in parallel offer approximately the same AH capacity as a pair of GC-2 6 volt deep cycle batteries wired in series. For those running heavy loads with an inverter a pair of 12 volts can actually be preferable as they're more likely to suffer less voltage drop under heavy inverter load than will a pair of 6 volts. The devil is in the details. ;)
  • Old adage ---One 12V battery good for One night of furnace
    Course your typical RV 12V battery is roughly 120 AH
    Two 6V batteries.......12V DC BUT higher amp hour ratings.....closer to 200 AH
    (TWO 12V batteries wired in parallel ----same 12V but double amp hour----12V/100AH each equals 12V/200 AH)
    (Two 6V batteries wired in series........double voltage but same amp hour----6V at 200 AH each equals 12V/200 AH)
    SO TWO 6V can provide MORE AH then ONE 12V
    What is AH Rating of current 12V?
    What is AH Rating of the 6Vs?
  • I used two 6's when elk hunting and recharged the next day. at first i used two 12's and then switched over to 6's. you will benefit with more power with the 6's then with one or even with using two 12's. the 6's will last longer
