- TOOBOLDExplorerAre you on battery or electrical hook up?
- Dick_AExplorerIf the cooktop is working the problem usually is the control board, igniter or the sail switch. The air stream from the blower swings the sail switch and allows propane to enter.
- Dick_AExplorerMoved from General RV'ng forum.
- RedJeepExplorerSimilar experience last winter with us. Controller board fried. Had to drive to Walmart and bought two electric heaters. The electric heaters turned out to be pretty handy and much quiter.
11 degrees? Buy some extra blankets and set your comfort expectations to low.
Good luck! - ScottGNomadMaybe the PP regulator has frozen. Does the stove still work fine?
If it has frozen then try putting a light bulb under it to keep it warm.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
