LaneS's avatar
LaneS
Furnace problems
I'm having problems with an old Hydro Flame furnace in my grandpa's camp trailer. The pilot light will light just fine, but when you turn up the thermostat, it never ignites the burner. It's a Hydro Flame Model No ARS-10L. Any suggestions?
  • BTPO1 wrote:
    Sounds like the thermostat is not working. I am not familiar with this heater, but if it has a wall mounted thermostat with a slide lever it is possible that the contacts are dirty and may just need cleaning. Possible also that a wire has broken or come loose from the thermostat or gas valve. I know that in my S&B I have to clean the contacts occasionally. JMO
    One area of the thermostat that should be considerd is the anticipator wire within the thermostat. It has a slide lever that rotates left and right along a very fine wire and is visable when the theromstat cover is removed. The wire does eventually break and is very very hard to see because of it's small size. Moving the adjuster all the way to it's stop to by-pass that circut. Set the thermostat temperature adjustment to it's higest setting. In this senario the furnace should fire up after a short delay while the system goes through it's start-up process. If no go remember to reset the adjuster back to it's original setting. If it does start-up yeah yeah!!! Repalce the thermostat .
  • DennisG9 wrote:
    Or the thermocouple has gone bad and it's not telling the gas valve the pilot is lit.
    Try Googleing the make and model of funace and you might find any quirks that pertain to your model.
    DennisG9,
    Thanks for mentioning the thermocouple. I had forgot about that and I just changed the one on my S&B a couple of days ago.
  • Or the thermocouple has gone bad and it's not telling the gas valve the pilot is lit.
  • Sounds like the thermostat is not working. I am not familiar with this heater, but if it has a wall mounted thermostat with a slide lever it is possible that the contacts are dirty and may just need cleaning. Possible also that a wire has broken or come loose from the thermostat or gas valve. I know that in my S&B I have to clean the contacts occasionally. JMO
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
