HighSpeedAlumin's avatar
Apr 10, 2016
Furnace problems
My furnace has never worked since I bought it new. so far we have spent over $750 to get it working and it has been reimbursed by the manufacturer, but I doubt they will offer to spend much more. We have had it serviced by three different technicians and I want to try to get it fixed so I can heat the holding tanks...every time I call Atwood they say to "do this" without hearing all the details and so their just guessing. So here goes.
It's an Atwood AFMD35 heater without the exterior door.
The fan works normal and you can hear ignition but the flame goes out 2-50 seconds after ignition every time. It will relight after a few seconds and the process repeats.
The ignition cycle never times out. It will continue to light and flame out indefinitely.
Circuit board has been replaced.
The propane line works well, as I have a buddy heater downline of the furnace propane supply and it works fine. (I don't use the buddy heater when trying to get the furnace lit.)
When the furnace was bench tested, it worked fine. When it was reinstalled, he put aluminum tape around the ducting insert into the furnace (at Atwoods suggestion) and it would stay lit on the second or third attempt. But has never been reliable at sea level altitudes. And won't start at all at 7000ft.
I suspect a intake/exhaust ducting problem. I just don't know where to start. It just seems like it can never get enough air. Any ideas?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Toddupton wrote:
    Have you completely bypassed the thermostat?
    His post indicates that is NOT the problem
    To the O/P. I am assuming it tries to fire 3 times then shuts down. If so check the curcuit board for a LED that should be flashing 3 times
    I do not now the particulars of YOUR furnace but if you are in S.E. Ga I'm 3 miles off I-95 and can take a look at it.. I had a problem like that with mine (Mine was the circuit board) and learned far more than I wanted to about RV furnaces tribble shooting..
    Here is a bit of info:
    There are basically two types.
    One has a single "probe" that is both the flame sensor and one of the ignition points.. IF it is lighting the ignition part is working
    The other has two probes, one ignition (often the gap is too wide) and one Flame Sensor.
    If you have the first, Circuit board problems are a major feature of that design..... but there is a cure.
    Tad late to the party..
    OP posted EARLY this AM what issue was and that it was FIXED :S
  • Wow! Thanks for sharing that information. I wonder how many others there are out there with the same problem.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
