HighSpeedAlumin's avatar
Apr 10, 2016
Furnace problems
My furnace has never worked since I bought it new. so far we have spent over $750 to get it working and it has been reimbursed by the manufacturer, but I doubt they will offer to spend much more. We have had it serviced by three different technicians and I want to try to get it fixed so I can heat the holding tanks...every time I call Atwood they say to "do this" without hearing all the details and so their just guessing. So here goes.
It's an Atwood AFMD35 heater without the exterior door.
The fan works normal and you can hear ignition but the flame goes out 2-50 seconds after ignition every time. It will relight after a few seconds and the process repeats.
The ignition cycle never times out. It will continue to light and flame out indefinitely.
Circuit board has been replaced.
The propane line works well, as I have a buddy heater downline of the furnace propane supply and it works fine. (I don't use the buddy heater when trying to get the furnace lit.)
When the furnace was bench tested, it worked fine. When it was reinstalled, he put aluminum tape around the ducting insert into the furnace (at Atwoods suggestion) and it would stay lit on the second or third attempt. But has never been reliable at sea level altitudes. And won't start at all at 7000ft.
I suspect a intake/exhaust ducting problem. I just don't know where to start. It just seems like it can never get enough air. Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
