Blanch's avatar
Blanch
Furnace Problems
My furnace will work if it is not plugged into shore problem. If I unplug it, the gas ignites and the furnace works. Plugged in, I hear it attempt to light a couple of times then it shuts down. Any suggestions?
  • enblethen wrote:
    Verify the voltage at the furnace when plugged in and when running on batteries.
    Possible converter is failing.
    YEP^^^^^^
    When NOT plugged in your Trailer Battery is supplying the DC for Furnace operation
    When plugged in the converter is supplying the DC for Furnace operation
    And converter should be maintaining/charging trailer battery
    Could be a capacitor is failing in the converter. Capacitors are used to 'filter' the converted AC to DC Power
    Unfiltered DC can charge the battery but will cause issues with circuit boards
    To check
    Use Voltmeter set to AC Voltage
    Then measure the DC System Voltage
    If you get a reading over 6VAC on the DC then converter capacitor is/has failed
    Otherwise...when plugged in Furnace should work better then when on battery alone
  • Verify the voltage at the furnace when plugged in and when running on batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
