coolmom42
Feb 27, 2016Explorer II
emcee wrote:
Sounds like the thermostat tolerance is too wide. Might be something like +/- 2 degrees default. What thermostat did you install? The tolerance may be adjustable.
Ex. In heating set to 70 degrees. Furnace comes on when temp drops below 68 then shuts off at 72. Will not come on again until temp drops below 68 again. When you lower the temperature setting manually you are resetting the thermostat and that's why it starts again.
That's what I'm thinking too.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
