wasatchmtnatvr
Feb 27, 2016Explorer
Dinosaur boards don't like rapid cycling thermostats or too narrow of spread. Something in front of heat vent forcing heated air to blow toward t-stat tricking it? Did you adjust t-stat heat anticipator to 1.0. If not try that. If t-stat contacts open and then close within 1.75 minutes it may shut off furnace with you using a dinosaur board.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
