enblethen
Feb 28, 2016Nomad
Did you set the anticipator when you installed the new thermostat? Most should be set about .80
Setting the anticipator to 1.0 will make the furnace try to keep temperature exactly as set. This is wrong. The furnace should only run about 6 times an hour.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
