duggram's avatar
duggram
Furnace runs, then quits, propane full, shore power
I researched this and found a good thread but my situation is a little different. My propane tanks are near full, the water heater and stove work fine. I'm getting my power from an RV park and I see no problems with power elsewhere. IF I turn the heat off at the thermostat for a few minutes it will come back on for 5 to 10 minutes, but then quits. It's 55 degrees in the trailer. thermostat is set at 75.
I tried the trick where you disconnect power to the furnace by pulling each fuse one at a time (of course they are not marked).
The furnace is a Suburban Dynatrail.
Where do I start to try and figure out the problem? I can't get to a shop for more than a week without causing a lot of trouble with my work.
BTW it has been 2 years since the furnace was in the shop for a checkup. But the trailer has only been used once for a few days since then.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
