Learjet's avatar
Learjet
Furrion TV DirecTv remote codes
Took a while to figure this out, since the Furrion TVs are not listed anywhere.
DirecTv remote codes:
39" Furrion works with code 10054
29" and 24" Furrion...code 10056
*UPDATE*
Just got the codes for my Genie RC73 remote for the Furrion TVs above.
For the Furrion 39" use JBL as the TV, then select I don't know my model, it will try code 1 of 1
For the Furrion 29" or smaller use Concerto as the mode and select I don't know my model, it will try code 1 of 1.
Hope this helps someone :W
  • Clay L wrote:
    I haven't checked this out because you have to register with the Furion forum to download the pdf with Dish and DirectTV remote codes, but if you need a Dish remote code it might be worth a look.
    ***Link Removed***
    The official answer to the Furrion universal remote codes is to use the LG Codes they are the same
  • Some how I lost the remote for Furrion Tv , bought a cheap RCA remote at Walmart tried code for Emerson TV brand code 10178 worked . Cheap fix for this trip .
  • I haven't checked this out because you have to register with the Furion forum to download the pdf with Dish and DirectTV remote codes, but if you need a Dish remote code it might be worth a look.
    Furion remote codes PDF
  • Most of us find that regular old LCDs hold up to travel pretty well.
