Snowman9000's avatar
Snowman9000
Fuse converter, or not?
Been reading archives, but not clear whether a converter's output should be fused. (This is not about the reverse polarity fuses found on all converters.)
I have a main battery fuse.
The converter can generate current independent of the battery.
But unlike a battery, it is current-limited. The former would suggest a fuse is needed; the latter would suggest it isn't needed, as long as the wiring is sized for the current.
I've looked at manuals for all the major converters. Most don't show any wiring or mention fuses. One shows direct wiring, no fuses.
Edit: I'm talking about a deck mount converter, near the battery.
  • Anything hooked to the battery will need a fuse. The battery is capable of delivering hundreds of amps during a short circuit. What if your converter shorts internally? How will it do with 100, 200, or more amps flowing thru the short before your main battery fuse blows?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
