corvettekent
Mar 01, 2016Explorer
Any wire between the fuse and the battery is not protected. The reason for the fuse is to protect the wire if it get shorted to ground. Yes it is safe to have the fuse in the batt. compartment. You should also have a fuse or disconnect switch between the solar panels and the controller.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
