kellertx5er
Mar 04, 2016Explorer
Dusty R wrote:
Fuse location depends on what it is protecting.
In this case it is protecting the wire.
In other cases it could be protecting a motor, so then you want the fuse close to the motor, which could be at the end of a wire a long ways from the source, battery or main panel. So here you would have 2 fuses, one at the panel and the other at the motor.
Dusty
The second fuse in your example is unnecessary. A single fuse at the source (panel) will protect the motor EXACTLY the same as one near the motor, and also protect the wire.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
