blueh20's avatar
blueh20
fusing both batt w charging relay what issues to expect?
I am running3-100w renolgy solar panels on top of my 2014 ford E250 van which go to a 40 amp renolgy commander controller then to a 255 ah lifeline batt.
Also have a Blue Sea systems charging relay ml-acr connected between house batt and starter batt with 2/0 wire pos and neg, 15' each way.
The house batt is the main batt and starter batt is aux.
Running a blue sea 100amp fuse panel(fused with 30amp breaker) for led lights, arb fridge and a flojet that pulls 7.5 amps max. All wiring is complete loops back to panel.
Theoretically my Blue sea charging relay is suppose to let the "house" battery start the vehicle in case the "starter" battery goes dead. Havnt tried it yet.
I just put a 150 amp marine type fuse on each positive battery post in case my 2/0 positive wire"between batteries" ever grounds out on the frame, my alternator puts out about 80-100 amps.
I am just about ready to start the vehicle up with the new fuses in place, what to expect?
I assume though if the house battery ever did try to start the vehicle with those fuses in place that the cranking amps would blow both fuses immedietally, is this correct????
if so is their anyway to have the house battery start the vehicle while still having some kind of " frame shorting" protection ?
thanks for your input.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
