sdetweil's avatar
sdetweil
FW 120v ac wiring guidance
I just finished the install of a Progressive Industries EMS unit (EMS-HW50C) for our 50 Amp service FW. I also added a transfer switch for the 7KW Onan generator I am installing in the front bay.
all works great.. the EMS unit also tells you the amp draw per leg.. nice info..
well, I just discovered that they wired it so that I have both A/C units AND the microwave on one leg.. the vac/clothes washer (not installed) and converter are on the other leg.
(had 'expected' to have the circuit layout like a normal breaker panel where the breaker slots toggle which source they are on.. WF8930/50 )
course they didn't leave enough wire in the fuse panel for me to just MOVE the hot wire around, so I will have to pull the thing out again, release the wire clamps and move the circuits around..
is there any guidance on what to put on what leg? What happens when you go to a 30amp service location.. I would use the dogbone, so I think both sides are still powered..just with less amp available..
the one leg ws pulling 16amp with the main A/C on. 28 with both.
thanks for any advice
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
