MikeJinCO's avatar
MikeJinCO
Explorer II
Feb 05, 2015
Garmin Coodinate System Change
My Garmin 2450LMT uses coordinates in the Degree/Minute/Second method< is it possible to change to the degree/decimal method?
  • Mike,
    Every Garmin I own (6 currently in service) has this capability.
    On the 24XX, I recall it is not in the setup. You have to walk in through
    Where To?/Categories/Coordinates - - Now you have to use the menu (stacked bars? -iirc) and it will ask Format? That is where you can select DDD MM.MMM (or something like that, I am not near any of them).
    Come back if that doesn't get you there.
    Matt - the perpetual navigator
  • Customizing the Device
    From Main menu:
    >Tools
    >Settings
    >System
    >Units.....—allows you to change the
    units of measure for distance.
  • All of the Garmin units I own allow me to change the format. Just browse thru the various screens looking for the option.
  • I would hope so. My rv model is decimal ( input) by default.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
