my 2001 cardinal came with this propane detector. cci propane gas leak detector 7771.2 I did not see any lights on, and when I pulled it out, one wire was disconnected. I connected it, ant the gree...
You might also check to see if your propane is now running - in the old days the CCI propane detectors controlled a solenoid device which controlled propane valve. As the CCI detectors went bad the solenoids remained shut denying owners use of propane .. some owners removed the solenoids others came up with alternative solutions.
