my 2001 cardinal came with this propane detector. cci propane gas leak detector 7771.2 I did not see any lights on, and when I pulled it out, one wire was disconnected. I connected it, ant the gree...
There are indeed combined LP and CO detectors. I can't understand how you can mount them.
The LP is supposed to be at floor level (so no good up in the bedroom of a 5er), while the CO detector alone, is supposed to be higher up. So whereinheck does the combo unit go?
IMO the only real way to solve that is to get separate LP and CO detectors, but you don't need a CO detector in a 5er since it does not have an engine. In a MH you need one of each of course.
