bbaker2001
10 years agoExplorer
gas detector
my 2001 cardinal came with this propane detector. cci propane gas leak detector 7771.2 I did not see any lights on, and when I pulled it out, one wire was disconnected. I connected it, ant the gree...
D.E.Bishop wrote:
I googled Propane leak detectors and see that Amazon has a replacement for your CCI. It is a Saf-T-Alert detector. I have a CCI that also controls a solenoid that opens a valve and allows the propane to flow. I believe that if the detector goes off, it closes the valve. Not sure about that. I love the thing but darn expensive to replace.
I will say that most if not all RV supply stores carry the Saf-T-Alert alarms. All three catalogs have them.
