Old-Biscuit
Sep 03, 2020Explorer III
RV LP SYSTEM is only .39 psi (11"WC)
So bubbles would be very small but odor can be very noticeable
Gas valves can leak thru
So you can check using SOAPY solution on connections/fittings to gas valve valve but furnace side of gas valve not so much
Bubbles can be used on fridge/water heater gas valves cause those are accessible W/O disassembly
SOAPY solution NEEDS to be thoroughly rinsed off
Gas Leak Detector best for checking furnace gas valve
