Sometimes I get bad gas, sometimes I get good gas. With a barrel of oil being so cheap, it it going to make adding ethanol to gasoline a cost prohibitive idea with so much surplus gasoline availa...
Not sure where (what altitude) you are having troubles but W/ my generator I try and use mid grade or up. Also as mentioned sea foam is a good additive but do not over load the mixture with excessive additive. JMHO
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
