Well.... I have seen the lab test reports, And the warnings from the engine makers, and have checked out the chemistry. There is evidence to suggest that higher concentrations of alcohol may damage engines NOT designed for it (Mercury Outboard Motor's test) Of course if the engine IS designed for it,, Then that test would not apply.
And there is a fact that alcohol contains less energy per gallon that gasoline so your MPG suffers with Alcohol. Without double checking the research (Which I do not feel like doing just now) I believe EtOH is about 10 percent less powerful, so E-10 should cost you 1% in MPG. That said I have seen much greater claims.
This I do know.. I ran low level alcohol (1-2% in my cars in the winter for many years (Standard/Amoco gasoline) before they were bought by BP.
They added HEET gas line antifreeze to the mix (At least when the driver was adding it, If they added at the plant I doubt they used that brand).. This is basically shellac thinner or Wood Alcohol, Works much like the grain alcohol they use today but a bit more expensive.
This worked as a gas line antifreeze because it dissolves water and carries it along into the combustion chamber where it is turned into steam and exhausted out the tail pipe.
Works very well in fact as I and a few others have proven.
I'm not sure what that water is doing to the engine either.
