NinerBikes
Jan 16, 2015Explorer
Gas question
Sometimes I get bad gas, sometimes I get good gas. With a barrel of oil being so cheap, it it going to make adding ethanol to gasoline a cost prohibitive idea with so much surplus gasoline availa...
wa8yxm wrote:
And there is a fact that alcohol contains less energy per gallon that gasoline so your MPG suffers with Alcohol. Without double checking the research (Which I do not feel like doing just now) I believe EtOH is about 10 percent less powerful, so E-10 should cost you 1% in MPG. That said I have seen much greater claims.
