jrloucks's avatar
jrloucks
Gas Valve Solenoid on Dometic RM 763 Fridge
I smelled propane and went hunting armed with a trusty spray bottle filled with soapy water. I found a leak on the housing of the propane/gas valve/solenoid in the rear of the fridge (Dometic RM 763).
I believe this is the original valve for this fridge based on what I've read. I also assume the valve is obsolete because of (more recent) Dometic field service articles referring to a "new" Weber gas valve.
Can someone confirm that the original valve is unserviceable?
I see a kit available on clearance from Camping World which includes: Gas Valve/Solenoid. Circuit Board. Thermocouple. Bracket. Installation Instructions. Ground Terminal
I already have a relatively new fridge controller card from Dinosaur Electronics (MICRO P-1338 REV 5) which supports the Weber valve. I can make a bracket for the new valve. So my preference is to purchase the Weber valve only.
If you've tackled this specific 'upgrade/repair' I'd love to hear from you.
  • Gas valves are NOT servicable. They are a replacement if defective or leak. Now, a individual may be able to find parts and rebuild, but any shop or technician would be a fool to rebuild a LP component that is NOT servicable. I would NEVER trust a rebuilt gas valve or allow my friends/family to be in an RV with one. Doug
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
