ksg5000
Nov 04, 2016Explorer II
There are only a couple of mfr and they are pretty much the same.
Many times the problem is as simple as the gasket getting out of alignment - the fix however requires you to disassemble the gate valve and many will just replace the entire gate valve as they aren't that expensive.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
