wa8yxm
Apr 09, 2015Explorer III
Thought 10% of the Capacity (C/20 rating) is recommended for best life.. That means a lot of generator time if you are boondocking on a dark day.. It would be my recommendation for your SOLAR though.. and do not forget the loads as well (Add a bit more for them)
For a single pair of GC-2, Xantrex suggests no more than 30% the c/20 rating (C/20 means capacity over 20 hours by the way). So that would make a 9260 or xx60 (I think it is the 4600 line that replaces the guts in many convertr/power distro panels) the maximum charger... You might wish to consider this one as when you need to crank the fuel burner... Burns less fuel
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
