hammick
Apr 09, 2015Explorer
MexicoWanderer I was hoping your would show up. You stated in another thread about charging a cell separately to raise SG on a weak cell. Did you mean a two volt battery or clamping a charging probe on a lead plate inside the cell of a battery?
Here is a charger to look at: CTEK charger
I own one of these. Regular mode voltage 14.4v at 4.3a. Cold weather/AGM setting 14.7v at 4.3a. Desulphate setting 15.8v at 4.3a Motorcycle setting 14.4v at .8a
No temperature compensation although it claims to reduce power at high temps. Not a fast charger but probably a good maintenance charger for auto and motorcycle batteries. Their more expensive chargers have a temperature probe.
Anyone have any advice on the power supplies I mentioned?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
