BrisketBiscuit's avatar
May 23, 2023
Generac shutdown issues, help!
First post, just a quick introduction, my brother and I have a food truck called Brisket Biscuit, so not technically an RV, but I'm hoping I can get some help for a few technical issues here. We bought our trailer pre-equipped, with fridge, freezer, hood vent, water heater, water pump, warming lamp, and ceiling a/c being the main electrical draws. The generator mounted to the front of the trailer is a Generac Gp8000e, rated at 8kW continuous and 10kW surge, going through a PD4560 distribution box via a 2m 10ga 4-prong extension cord. We haven't had any issues with the unit except for the noise level, so I built an enclosure (described below). With the enclosure in place, the generator shuts down after just a few minutes, even with minimal load. Even with only the hood vent (2400W) and some led lights, it'll run for a little bit then shut down. It isn't any hotter than without the box thanks to the beefy fan, and it starts right back up, so I can't figure out what's causing the shutdown.
The enclosure is 1/2" MDF with 2mm butyl/foil sound mat inside, then 1.5" acoustic foam panels inside that on the top and long sides. The ends are pretty open, with 3x 120mm fans pushing in the intake end and a 10" radiator fan (~800cfm) pulling out the exhaust end. The exhaust itself is extended outside the box, so fumes shouldn't be an issue, though I'm not sure. The pipe turns 180 degrees and is attached to the side of the box pointing toward the intake end, but I don't think that's the issue. There are also openings for accessing the control panel and fuel filler that I keep open when running.
My next step is to change the routing of the exhaust pipe so it points down, but if that isn't the issue, does anyone have any suggestions? This thing is loud and I'm afraid it's hurting our business, and the box makes it significantly quieter, but that doesn't matter if it won't stay running.
  • Off the cuff, looks like you have the airflow for cooling pretty well designed (and you confirmed it’s not getting real hot inside).
    That said, the mufflers on, well, any engine, but on small engines that run full throttle get VERY hot. Ever see it at night? My home generator (similar to yours) and big mowers will get glowing red hot under sustained load.
    Could be some localized heat maybe causing a vapor lock but it wouldn’t restart instantly I think.
    Exhaust back pressure could be an issue too. Maybe test the absolute shortest straight run of exhaust pipe to get it clear of the enclosure and see if that helps.
    IMO it’s likely heat or backpressure if it runs fine “naked.”
  • Brisket,
    I have a newer version of the same generator.
    I would guess from the pictures that there is a big heat build up in the carburetor area. Put the exhaust heat alone that side of your box. You might think about looking up a Gen-Turi as an exhaust. That won't help with noise much, but it will get the exhaust up over the roof.
    I can't promise that will help with the shut down. I might be cleaner.
    Matt_C
  • CA Traveler wrote:
    Is it OK with the box off? Point the hot exhaust straight up through the top not down. Shield the serving side only.
    This. Run it with the box off and you'll know soon if that's the issue. Another simple, free thing to check is to ensure the correct oil level. Very simple thing, but it will cause the issue you're describing.
    And, based on the name of your food truck, I very much want to try it! Too bad I'm not in your area!
  • Is it OK with the box off? Point the hot exhaust straight up through the top not down. Shield the serving side only.
  • I don't know if the generator error light is coming on, because I stupidly didn't cut the access panel wide enough for it to be visible (I actually didn't even know the light was there, the plastic on the control panel is really yellowed and makes it hard to see). I'll check next time it happens.
    Based on what I can feel by reaching inside, the big puller fan seems to keep the air temp around the unit as low or lower than it is without the box, so I didn't think that would be an issue, unless there's some particular part that's heating up more that is causing the shutdown.
  • Are you getting a code? My guess is it's going into over heat shutdown mode. Open air generators are just that and require passive air around the unit to cool it. By enclosing it you are trapping all the heat. It shuts down as a self protective measure. That's my deduction, since you said it ran fine before you enclosed it and now it doesn't. If they were meant to be enclosed they would have come that way. Even vented, the pics show it's pretty buttoned up and the sound mat and foil is just insulating it's own heat.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
