06GTORR
Aug 15, 2017Explorer
generac xg8000e low voltage/ engine wont rev up
generac xg8000e low voltage/ engine wont rev up with load to increase volts to match load .
need some help trouble shooting the thing i used a muilt meter to test HZ and volts got 55HZ 98 volts
went under gas tank turned a screw got 62Hz and 126volts now at idle/ no load.
Plugged in a flood light got 61HZ 123 volts then plugged in small air compressor volts dropped to 98.
I reach up under the fuel tank pushed on the gover spring and volts shot up to 140 with the air compressor running so i know its got the power but its not adjusting under load ?
Need ideas im out ?
Need ideas im out ?
