tntcrock's avatar
tntcrock
Generator ??
I run my 5th wheel on generator while on private property w/out power.
I hook up to the generator on the 4 prong 30 amp output. I plug into this with a 50 amp to 4 prong generator setup i made; then i plug my 50 amp camper card into it. I'm trying to figure out if i get better power with this, since I'm getting to hot wires to camper. I would like to do away with using the heavy 50 amp cord. Would like to put my 50amp to 30amp adapter on the rv and then plug into generator cord. That would put 1 hot line coming from generator to camper and then splitting it back to 2 lines in the 50 to 30 amp adapter. I only use 1 a/c when on generator.
  • When A/C is not needed it would be easier to recharge with a solar system.
  • Probably should tell us a bit about your generator, particularly what size is it in KW? Also, on the four prong generator output, is it 120V or 240V. Might help to explain why there is a 4 prong outlet on the generator.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
