swimmer_spe's avatar
swimmer_spe
Generator calculation
I want to run some power tools at a camp I own. The issue? There is no power there. I have a small generator (it is currently buried in my garage at the moment).
Power tools are rated in amps. Generator is rated in Watts.
How do I figure out the max amps my generator can do?
  • swimmer_spe wrote:
    westend wrote:
    Watts = Amps x volts.
    Also, pay attention to the operational rating. Your generator may be able to handle 20 amps for a small instant but may fail if run continuously at that rate.
    I know about the continuous rating.
    Using your calculation, a simple 1200W generator that puts out 120v will give me 10A?
    This is correct.
  • You certainly will not want your little generator running full out all the time to provide the required power. So get one that provides more than you think you need.
  • Ralph Cramden wrote:
    With power tools a circular, mitre, or table saw is going pull the most amps unless your using a large roto/demo hammer at camp, usually 13 to 15 amps max if it's a quality piece and not a China Freight POS. Any of the small 2000 wattish invertors will handle it.
    I know mine is less than 2000 watts, and I think it is not an inverter.
  • With power tools a circular, mitre, or table saw is going pull the most amps unless your using a large roto/demo hammer at camp, usually 13 to 15 amps max if it's a quality piece and not a China Freight POS. Any of the small 2000 wattish invertors will handle it.
  • Watts = Amps x volts.
