plumber2311's avatar
plumber2311
Generator hard start
My rig has a Generac Guardian Quietpact 40G gen set.
It has been giving me a hard time. I found the carb was varnished, and the fuel solenoid was no good. I've since replaced the carburetor. Now the generator only starts if I hold the throttle closed. The choke appears to be cycling normal, and I have fuel.
It seems odd that I have to hold the throttle closed, to start. After it starts, if runs fine. I can also restart hot no problem.
I'm stumped now.
  • sprays don,t do much more carbs, it goes right to the piston, t6ry sea foam in the fuel ,it,ll clean things up.
  • I'll 2nd Seafoam but you may also have a bad/hardened float valve o-ring.
    Seems to be a common occurrence ever since ethanol has been added to gas.
    I've had this problem a couple of time on other small engines
  • I tried the spray before I replaced the carburetor. I haven't added any to the fuel.
    I've also verified strong spark, and replaced the spark plug while I was at it.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
