WyoTraveler
Sep 29, 2014Explorer
Because generators now consume current they can be a problem. If your house battery goes dead from over use and generator is hooked up to it you won't be able to start the generator. The solution on some of the newer MHs was to connect the generator to start battery but they isolate and charge the start battery any time the MH is plugged into power or into a running generator. You can buy an adapter charger that will accomplish the task. Just moving the generator over to the other battery may not totally solve the problem.
