whover's avatar
whover
Generator, no power after 20 sec
Good morning RV'ers,
Needing a little advice. I have Guardian (Generac) 004700 generator in my class C that runs flawlessly. After about 20 to 30 seconds I lose all power (no substantial load), even to timer remote panel in coach. Power off generator and wait about 2 to 3 minutes and same happens again. I have checked and breakers are fine. They do not seem weak or tripping. Any suggestions T/S this type problem. Thanks
  • Sorry for open end question. To answer a few replies, this setup does not have a TS switch. Manual switch over thru plug. No power at plug after 20 second run, nor power out from gen after 20 seconds. The motor continues to run just no power after that 20 seconds or so. The issue seems to be within the Gen
  • Generator is running?
    No power in RV?
    You need to verify power out
    Start at the transfer switch, it might be failing
    You need to open the cover and check voltages while generator is running
    Get somebody who knows what they are doing
    If the generator is ok, and it is a TS failure, their will be live hot voltage on those wires, coming from the generator to the switch
  • You need to narrow down the possibilities from a few thousand to a few hundred. Get a voltmeter and start at the generator and work your way down the line to determine where the breakdown starts.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
