puttd's avatar
puttd
Generator not powering ac/tv/micro
I am driveway docking at a relatives, with marginal voltage.
Generator is starting, is not powering anything, eben when unhooked for all power. Inverter is working for micro and tv, not enough for ac though. Shore power is working except if there is any slight increase in load on the circuit load.
I have reset all circuit breakers multiple times. I have reset all gfis when show power ample.' Have received error message "ac overload" on the magnum panel, but no need to reset the inverter for inverting or shore power
Any ideas?
  • Which problem should we focus on first?
    puttd wrote:
    Shore power is working except if there is any slight increase in load on the circuit loads?
    Not sure what that means.
    I'm not sure what that means? Are you running your generator while hooked to shore power?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
