Bowfreak's avatar
Bowfreak
Generator questions
We own a 2003 Trailmanor 2720 SL camping trailer. It has an RV Products 8000 model rooftop AC. I am assuming that is an 8000 btu AC unit but can't find anything on it. I have pulled the cover and read the owners manual and about the only thing I can find is the maximum amps on a tag on the AC unit says 20 amps.
I have a ton of Cabelas points and would like to use them on either the Champion 1600/2000 watt inverter or the Champion 2800/3100 watt inverter. I would really like to go with 1 of the 1600/2000 if possible because it's only 48 lbs dry weight and will be easy to get in and out of the truck. Will the 1600/2000 be enough to get the AC started and going?
If not would it be better to get 2 of the 1600/2000 and run them parallel or just get 1 of the 2800/3000 watt inverters? It will be more expensive to get 2 of the 1600/2000, but if we are camping where or when we don't need AC we could just take 1 with us.
My only concern with running 2 1600/2000's in parallel is that they actually have less surge power than 1 2800/3000. Please let me know and thanks for your time.
The other thing I noticed is the 1600/2000 watt doesn't have a 30 amp plug in but I am not sure that will or won't change things.
Having RV issues? Connect with others who have been in your shoes.24,355 PostsLatest Activity: Jan 30, 2026
