havasu's avatar
havasu
Generator quits after 10-15 minutes
It's an 5500 Onan Emerald Plus with 900 hours. Engine starts and runs nicely.
Drove it for about 3 hours back in March running the roof air with no problems.
Left CA yesterday to drive to Las Vegas and after 15 minutes or so it quit - would restart for 30 seconds and quit again. The only load was a single roof air.
Stopped a couple of hours later at a rest stop and it started right up. Tried the AC again and it ran for another 10 minutes and quit again.
The only difference from March to yesterday was the temperature - we were driving in 115F.
Could temperature be the problem? I had an RV tech take a look today and he scratched his head, said the engine was running great and it was just overheating due to the ambient temperature due to the heat off the roadway - I just wanted to know if he was blowing smoke or whether heat is the only problem?
  • lp gas or diesel
    i had a problem yesterday/sunday with my LP onan, wouldn't run under load
    problem turned out the propane tank valve for the Onan was not open all the way
    fuel starvation, on top of that the low flow was causing line freeze (vapor freeze ??)
    the lines and valve were all frosted up
    problem was corrected as soon as i opened the valve all the way
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
