oldwizard1's avatar
oldwizard1
generator remote start
I am having trouble with my remote start on my Rexhall vision mh. The generator (generac 5000) will usually start from inside motorhome but it takes a lot of cranking. If I go to the generator itself and start it, it starts in a few seconds. Whats the deal. Thanx
  • You appear to have the same unit that I have on my Rexhall Vision. I experienced the same problem you are having and was able to trace it down to the plastic cover over the choke solenoid. I moved the cover out the thickness of a small washer and it is no longer sticking and it now starts from inside again. When inspecting the cover I could see where it was rubbing. Basically it was a choke problem. JMO
  • Thats correct all I do is kick it over from either location with no priming. I do hear a relay kick in when I use the dash remote.
  • Harvard wrote:
    Assuming it is not fuel injected I would suspect it may have something to do with a sticking choke, that is sticking open.
    I "assume" he is doing exactly the same thing whether inside or out? just pushing the button, not messing with the winter/summer switch, etc.? does the inside switch carry high amperage or is it relayed?
    bumpy
  • Assuming it is not fuel injected I would suspect it may have something to do with a sticking choke, that is sticking open.
